Sea urchin strange sounds :(
Started by Gledison, November 02, 2013, 06:18:30 PM
Quote from: Gledison on November 05, 2013, 08:15:35 AM
Quote from: jimilee on November 05, 2013, 04:03:08 AM
Quote from: Gledison on November 04, 2013, 10:48:55 PM
Quote from: jimilee on November 02, 2013, 07:29:09 PM
I noticed some stuff like that as well but it's controllable. Still sticking with the cave dweller though. I am out if town or I would have posted the values.
Hey mate, could you send me the values for the sea urchin components?
thanks a lot!
Gledison
like the build docs?
Well, the IC pins voltages, voltage regulator values, etc...
Do u have it?
Thanks mate
i can get that to you tonight
Gledison
Quote from: jimilee on November 05, 2013, 05:35:01 PM
thanks a lot!
Gledison
Do u have it?
Thanks mate
Thanks Jimi!!
chromesphere
Master  :o I don't think so Gledison :)
Im not sure about the regulator.  I had a rebote once that I was powering off 9v battery.  The battery went flat and the rebote when absolutely mental.  Ear piearcing.  Nearly deafened me.  Maybe your circuits not getting enough power or maybe the dc power pack isn't outputting enough?
Paul
Quote from: Gledison on November 05, 2013, 06:05:44 PM
thanks a lot!
Gledison
Do u have it?
Thanks mate
Thanks Jimi!!
De Nada
PT2399
5      2.4
2.4   2.4
0      2.4
0      2.4
2.9   2.4
2.4   2.4
.2     2.4
.6     2.4
TL072
4.2      8.4
4.2      4.2
4.1      4.2
0         4.1
Regulator
8.4
0
4.9
Gledison
Quote from: jimilee on November 06, 2013, 02:14:24 AM
thanks a lot!
Gledison
Do u have it?
Thanks mate
Thanks Jimi!!
De Nada
PT2399
5      2.4
2.4   2.4
0      2.4
0      2.4
2.9   2.4
2.4   2.4
.2     2.4
.6     2.4
TL072
4.2      8.4
4.2      4.2
4.1      4.2
0         4.1
Regulator
8.4
0
4.9
Obeigado Jimi lee!
How do u know i speak portuguese?:S
Cheers
Gledison
Quote from: chromesphere on November 05, 2013, 10:17:51 PM
Paul
Hahah! For me you will be. Your videos put me in this hobby!!
Mate, ive got the values feom Jimi Lee and will check it out! One thing for sure is that rhe 1Spot output is constantly 9,3V
Cheers
Quote from: Gledison on November 06, 2013, 08:26:43 AM
thanks a lot!
Gledison
Do u have it?
Thanks mate
Thanks Jimi!!
De Nada
PT2399
5      2.4
2.4   2.4
0      2.4
0      2.4
2.9   2.4
2.4   2.4
.2     2.4
.6     2.4
TL072
4.2      8.4
4.2      4.2
4.1      4.2
0         4.1
Regulator
8.4
0
4.9
Obeigado Jimi lee!
Cheers
magic!
Gledison
Quote from: jimilee on November 06, 2013, 02:15:23 PM
thanks a lot!
Gledison
Do u have it?
Thanks mate
Thanks Jimi!!
De Nada
PT2399
5      2.4
2.4   2.4
0      2.4
0      2.4
2.9   2.4
2.4   2.4
.2     2.4
.6     2.4
TL072
4.2      8.4
4.2      4.2
4.1      4.2
0         4.1
Regulator
8.4
0
4.9
Obeigado Jimi lee!
Cheers
magic!
What a hell? ;)
Gledison
PT2399
5      2.4
2.4   2.4
0      2.4
0      2.4
2.9   2.4
2.4   2.4
.2     2.4
.6     2.4
TL072
4.2      8.4
4.2      4.2
4.1      4.2
0         4.1
Regulator
8.4
0
4.9
[/quote]
Sooo,
my values with the battery are relatively similar.
With the PS , things are a bit different.
I've noticed that with a PS the values on pins 3 and 4 should be 0. My pin 4 is always giving some leak (0,25V)
on the regulator:(im using a inverted 78l05)
7,7
0
6,8V
This leakage on pin 4 could be the prob? or the regulator values?#the TL072 is fine.
ive checked the pins 3 and 4 and there is no bridge between than, only when the IC is plugged.
any ideas??
cheers
Different regulator maybe? Then maybe the ps
Gledison
Quote from: jimilee on November 07, 2013, 12:41:07 AM
Hey Jimi, did u use the LM7805 with this enclosure?
Nope, I will have to look to see which one I used. I don't remember right off. I should have looked when I took readings, but the writing is so tiny.
Gledison
Jimi, no need man!
The problem was solved quicker than expected!!
I've read that the  78L05  has an inverted pinnout compared to the suggested 7805!
first build!
BUT, in the layout I've got , is showing the orientation of a 78L05! I know I should have followed the schematics and the pcb traces, but following the datasheet it was obvious that I should invert mu 78L05 in order to fit in this 7805 layout.
Actually, I inserted the 78l05 in the same orientation as the 7805 and I've got the perfect measurements!!! How odd is this? or the noob here is so stupid? I don't get it!!
Cheers
Gledison
Quote from: jimilee on November 07, 2013, 07:30:39 PM
Yaaaayy!
You saw this pinnout diagram? the 78L05 I've got have different layout! damn it!
Valeu a ajuda Jimmi!
