Cap 26 for Aquaboy...workaround?
Started by MattL, February 22, 2011, 12:16:21 AM
MattL
For the Aquaboy I'm unable to find a 39n for capacitor 26 - which I'm aware is the same as .039u. Small Bear turns up nothing, same with Pedal Parts Plus. Mouser, of course, has around 80 billion, but very few low voltage, and mostly if not all out of stock, and something like 32 or 36 weeks before they're expecting any (?!!?) more. So I need a workaround. any suggestions? Thank you, Matt.
irmcdermott
It's also the same as .039mF. SmallBear has the Panasonics (688 of them).
SKU: 1101
MattL
I did a search at Small Bear and there was nothing I could find, but maybe it's sensitive to the "n" vs. the "u". Thanks, I'll check back.
MattL
Got 'em, but it did say they were no longer in production, so people should jump on them now!
rhcp311
I'm still waiting on my 39n caps to show up from Small Bear. In a moment of desperation I almost considered running a .1uF and a .068uF cap in series into that spot on the PCB since that would give you a total capacitance of ~ 40n. I decided to hold off though, so I didn't try it, but mathematically speaking, that way should work.
