Several FATpants Builds
Started by Beerdog80, February 20, 2011, 01:45:18 PM
These look as good as any commercial pedal out there. Nicely done!
bigmufffuzzwizz
Is the trimpot you used from tayda??
Beerdog80
Beerdog80
Quote from: madbean on February 25, 2011, 12:03:40 PM
Thanks bro! I ordered a couple of sunkings from you the other day.  That will be my next MADBEAN project!
jcuempire
Fantastic work.  Unbelievable
Beerdog80
Quote from: jcuempire on February 26, 2011, 01:27:31 PM
Thanks.  Another I did up the other day.  Obviously got the visual que from Fastocker's build a few months back.
I made this a 'test' enclosure to test the color mix I made on a unfinished (mostly) enclosure.  Worked out pretty good. I hate painting on unfinished enclosures.  Always shows the imperfections of the surface below the paint.
bigmufffuzzwizz
Quote from: Beerdog80 on February 26, 2011, 02:04:39 PM
Have you tried doing a wet sand before painting them? I use 400 grit and then move to 2000 grit and i end up with a super smooth enclosure. sometimes i don't even wanna paint it afterwards!
Beerdog80
#22
Quote from: bigmufffuzzwizz on February 26, 2011, 03:05:05 PM
Of course.  This one was blocked sanded with 200, 400, 600, 800 and 1000.  2000 grit is actually too much except for finial finishing.  You have to leave something for the paint to stick to.  After sanding, I hit it with scotch brite medium pads to give it a little more 'bite'.
  Problem isn't so much the finish on the enclosures but how some have such large pits and casting marks that painting is ok but if you put a decal or graphic on it, it leaves a nice, large space for air to collect.  Not a good thing for a graphic.  To correct that, you would have to poly fill, THEN sand to smooth the surface but it's far easier just to buy a polished enclosure.
 The one above was wet sanded after the final clear with 1500 and 2000, then buffed to a mirror shine.  If you look closely at the top left pot hole, you can see a pit that I would have had to fill if I wanted a perfect surface....but since this was a test template of sorts, didn't care.  :)
If you start lower, with an 80 or 100 grit you can get it smoother. I use an orbital sander for that low and it gets stuff down past the surface irregularities.
Beerdog80
Quote from: jkokura on February 26, 2011, 04:39:56 PM
  True, but then I'd have to pull out the DA and turn on the air compressor.  Still cheaper and easier to buy a polished enclosure.  Saves a massive amount of time so I can get stuff in and out quickly.
Oh no doubt, for the average person, it's a good method I'd say.
jacob
Beerdog80
Ok...final enclosure for this project.  :)  I can't wait to get this one done and a picture out in the sun.
k.rock!
God bless!
www.kalebromero.com
sgmezei
Hey man those things look wicked!! what mods did you do on the 3 knob version with the switch? I have built one and am wondering if I should change it.
Also, do you use a primer on the enclosures before you paint them? or do you just sand them and apply multiple coats?
Thanks, and again, they look AWESOME.
small fish
Thumbs up! They´re perfect!
Any chance to get a detailed "paint report"?
Guitars are made of trees! Paper is made of trees!
Recycle your paper, so there are more trees left - to make guitars!
