Dub Dweller
Started by alanp, October 13, 2013, 01:31:35 AM
A while ago, I did a Dub Edition Cavedweller, and put it in a 1590B enclosure, being new to this building lark. Now I've got one or two more builds under my belt, I decided to do it again, but in a 1590A like Bean intended.
Yes, the icecream shim is essential for it to work. Good ambient delay, or noisemaking with the oscillations from the Mix mod.
My first delay, and still a staple on my board today.
Ettore_M
Well done! I love the simpleness of the sharpy labelling!  :)
Did you use 1/8W resistors (the little ones) to get it to fit? Or standing resistors? Because I'm considering of making one for me and I don't think I can get it to fit with standing resistors.  :-\
Hector
- Culturejam
1/4 watt standing resistors. It does fit, but only JUUUST. (This is with socketed IC's.)
Ettore_M
Quote from: alanp on October 13, 2013, 04:07:26 PM
Socketed ICs? That's unexpected! Well done!  ;)
Hector
- Culturejam
I used the cheap sockets, not the machined ones I'd normally use -- the cheapo ones are ever so slightly shorter vertically. (Same reason I used 'em on the Wicked Switch boards.) Cheap sockets are a pain in the ass to put IC's in, compared to machined pin ones.
