Led causing popping?
Started by ch1naski, October 06, 2013, 11:39:35 PM
das234
Quote from: jimilee on October 07, 2013, 02:20:24 AM
Well that's awesome, a little piece of vero should do the trick. My delays are the only ones that pop for me. Usually during set up, I'll switch them on and off a couple of times, usually does it.
FYI Jimi, I tried the little vero trick with the resistors and cap for my Sea Urchin and it made the pop WAY worse and very persistent.  I'm going to take it out, unbox it, and put it back together with a 100k PDR and cross my fingers.
Tonight I noticed when I use my jbass, the delays don't pop
ch1naski
I used input/output pdr's on my last Galcticon, and experience no popping now. The one previous (my original problem), I used the amz popping solution (cap and resistor) plus the pdr's. It worked. But not sure if it was the added pdr on output or the amz  anti-popping scheme.
Sent from my SPH-L710 using Tapatalk
one louder.
ch1naski
Quote from: jimilee on October 29, 2013, 02:19:18 AM
do they slap? (Bad funk bass joke).
one louder.
Quote from: ch1naski on October 29, 2013, 03:02:47 AM
aaaahahahahahaha...nope but they are in fact stankey.....
