How to build and Use a Basic Testing Rig
Started by jkokura, February 14, 2011, 05:06:08 AM
Om_Audio
Thanks man!
C
Quote from: jeffaroo on January 15, 2013, 08:48:58 AM
that ^^^ is awesome ! a true pedal builders build. love the look.
even with custom cap calculating on the workbench !
Stomptown
Quote from: jimilee on February 07, 2013, 04:37:02 AM
Nice,I sed the alligator clips and for an audio probe,I just grab typically a small screwdriver and clip it to the audio out.dual purpose and it works well.is that a volume pot? I'd love a way add the pots without soldering them until I'm ready to box it.
Good Idea! And yes that's a volume pot. I just made the wires extra long so I can remove it later and cut down to the length I need for the enclosure. I would love to have a bank of pots that I could wire up to terminal strips so I could avoid soldering the pot on for testing. Maybe a test rig in a larger enclosure with lots of pots, an led and true bypass wiring!
AllenM
Following Jacob's guide I went and built a testing rig. Man this thing is handy! Added a toggle for the probe / output gator clip.
And of course my quality control supervisor had to sign off on the build...
AllenM
That looks awesome Allen. Curious what you got those black hole things for the clips...
AllenM
I found those at a local mom and pop electronics shop and use them to plug "extra" holes in enclosures. I did a quick google search "plastic hole plug" and found this
http://www.mouser.com/catalog/catalogusd/645/2667.pdf
The type B look to be similar. I also have some that are metal for larger holes.
For the above project I drilled a hole in the plug big enough to run the wire thru.
AllenM
das234
Ok.  I'm onto this project.  I drew up my own (crummy) little diagram for this so I can build it.  Am I correct that the enclosure provides the ground connection from one jack to the other so I need a conductive enclosure to make that happen?  I have an old cigar box laying around I was going to use but I don't think that will work.  Or can I just add a wire somewhere to fill in the missing link?
Haberdasher
yes, you're right- the metal enclosure automatically grounds the other jack.
my test box is pvc or some other plastic.  I just ran a wire from the grounded sleeve to the other jack's sleeve and that worked fine.
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
das234
Outtagetme
Hi everyone, this is a very interesting post!!!
I'm planning to build my own testing rig, along with an audio probe, and I was wondering if I could use a RCA plug as a probe, since I don't have any spare multimeter tip. I have an old RCA connector, with a 3-pin end on one side (red, black and yellow) and 1-pin on the other end. Maybe I could use one of those wires (along with the connector) for my audio probe, what do you think?
Ciao,
M.
das234
It seems to me those plugs would be awfully difficult to probe a PCB accurately.  You'd probably have better luck making a probe from a piece of solid core wire thick enough to hold its shape but thin enough to get into the tight spots, maybe 20g-24g.
das234
I thought I'd share my test rig that I built using an old cigar box and a lot of helpful tips from this thread.  You may notice I have not installed a test probe.  I haven't needed one yet (knock on wood) but I'll solder one in if the time comes that I need to troubleshoot something with it.
Those pictures are tiny, got a better one?
gingataff
das234
Quote from: jimilee on May 20, 2013, 02:44:54 AM
That's weird.  I took the picture on my phone and uploaded it just like I did with the pfannkuchen pictures and those were fine.  I'll see what I can do to fix it.
das234
This is better. You can see it's got plenty of room to tuck away the leads inside the box for storage.  And the enclosure cost me zero dollars.  That's a good price.
