?Any soundclips for Yellow Shark and SilverFox
Started by sjturbo, February 13, 2011, 04:45:05 AM
sjturbo
Morning, I am thinking of building either the Yellow Shark or SilverFox. I'm hoping someone has built them and can share some soundclips? Anyone??
I don't have any, but I've built both of them. What are you hoping to find out?
sjturbo
Thanks for the reply. I have not built either but am looking for a dynamic, touch sensitive overdrive in the zendrive region. What is your sonic opinion and signal train?
Thanks!
Well, if you want a zendrive pedal, the serendipity is what you should build. The Neutrino might also be a good option for you.
I didn't like the yellow shark as much as the silver fox personally. I think the silver fox has more 'tweakability', meaning it's more flexible. I can also tell you that the silver fox is from the schematic David Barber shared with the DIY community, so it is a verified schematic, and %100 authentic. It's a pretty cool thing.
My signal chain depends on my mood. I own more than 50 guitar pedals, of which I'm constantly selling or trading or buying. I can tell you that right now I play through a stock 09 Epi Dot, a mid 70s silverface Vibro Champ, and I often play with pedals one at a time instead of on my board. When I do play out, it's usually P&W stuff. But I've been known to show up at open mics and Jams, and the odd coffee house gig. I havent gigged with a band in years, but I miss it.
sjturbo
Thanks for the prompt reply. Actually I have a Zen Drive and the Neutrino, as well as the Quasar. I use the Q and N more often than the ZD. That said I think I may see if the Serendipity pcb would accomodate the Zenkudo mods. I like what I have heard on ytube.
