Egodriver LED Problem
Started by CMinusInGym, February 13, 2011, 02:28:12 AM
CMinusInGym
Hi, I'm building my first Madbean pedal, an Egodriver OCD Clone, and have a problem with the LED.  The pedal works fine and sounds great, but the LED does not work.  I've tried switching the contacts and even trying a new LED, but neither have worked.  Any idea on what might be causing this?
Thanks for any help!
Have a look at the wiring diagram here...
http://www.madbeanpedals.com/forum/index.php?action=dlattach;topic=707.0;attach=212;image
Lug 'A1' of the 3PDT goes to the hole marked 'SW' on the egodriver board, the Square 'LED' hole goes to the long leg of the LED (+) and the round LED hole goes to the short leg '-'
Hope this solves your problem :)
CMinusInGym
so if the SW wire isn't connected correctly, the LED won't work?
Thanks I'll check it out!
CMinusInGym
Ok, I tried everything with no avail.  Could it be something else?
Please post an close-up pic of your led and switch wiring.
CMinusInGym
Okay, I solved the problem and the LED lights up, but when I bypass the pedal, it stays on.
I think there is an accidental connection, but I'm not sure between which parts.
I'll post a pic as soon as I get a chance.
If it's staying on then somehow the negative end of the LED is always connected to ground, rather than only when the switch is engaged. So, I think somehow the switch wiring is incorrect, or you ran a wire from the wrong pad on the board. We'll know a little more once we get that picture!
CMinusInGym
I partially fixed the problem, but now I have a bigger problem.  The light turns on and of when on/bypassed, but when I plug my guitar in, the LED goes faintly on and the guitar level drops.  When I roll back the guitar volume, the LED grows brighter.  When I turn the effect on, the LED lights up fully and the volume mutes.
(I'll take a picture as soon as I can)
Whoa! Sounds trippy! We definitely need more info and pictures.
CMinusInGym
Alright, I figured it out.  In case anyone else ever gets this problem, it was the SW and input tip connections touching.  It finally works and sounds amazing!  Great pedal Madbean!!!  ;D
