Need help with a tranny
Started by Mark_McQ, February 08, 2011, 01:11:47 PM
Mark_McQ
I woke up this morning and he won't leave....
Oops, no, not that.
Bought a pair of BC190C's to put in my Crybaby. I was anticipating the TO-92 style plastic ones, but they're the metal cap style, as pictured below. So I don't know which leg is which. I presume the small metal tab on the cap is to designate one of the legs.
Can anyone help me id the legs?
Mark_McQ
Nevermind, after googling for a while, managed to find out it was a TO-18, and then found the pins right away.
As far as I know, for future readers, the tab indicates the emitter. Never assume with a transistor, look up the datasheet before installing and learn to read the schematic for double checking the orientation.
Tab is the emitter.
Let me add, though, that IMO that BC109 would be much better used in a fuzz rather than a CB!
Mark_McQ
I opted for those after seeing them suggested on a thread on FSB. They're a superb upgrade. I'm very pleased with the results, they really show the stock MPSA18's up.
Well, scratch my belly and waggle my tail! I will definitely try this out, then. It will be pertinent to the upcoming Weener Wah.
Thanks~!
Mark_McQ
From what I read, only Q1 needs changed, as it has the most effect. Although I just chucked the pair in.
I have my Crybaby modded with both the red and yellow fasels and a switch to toggle between them. After adding the BC190's, I can now hear a bigger difference between the fasels than before. There's more clarity too. The wah sounds more throaty.
Do you have a preference on either of those inductors? I'm going to try the Whipple on mine.
Shoot, now I'm all jazzed to get the Weener finished!
Also, I really need to re-grease my Crybaby...what do you use, Mark?
plesur
I use white lithium grease. It comes in a spray can. I find it easiest if you spray it on some card first and then use an ice cream stick to apply it on the rack and pinion, otherwise it spatters everywhere.
Mark_McQ
Quote from: madbean on February 09, 2011, 01:42:11 AM
I tend to favour the red one. Seems more 'deeper' than the yellow.
If I had to describe them, I'd say the yellow was more 'classic'. Like a better version of the stock one. The red is more raw.
I couldn't comment on what grease the use. Mine is still fairly gooey.  ;D
Mark_McQ
ckim715
Where'd you get the BC109s? I've been looking for a couple to put in my wah as well.
-Charlie
Smallbear has them. Or, you could do the poor-man's version of metal can 2n2222. That's actually what I have in mine.
Mark_McQ
Quote from: ckim715 on February 10, 2011, 04:34:20 AM
I'm in the UK, so I use this site:
http://www.doctortweek.co.uk/
Usually have my orders from there within a day. Awesome site.
