A/B/C Pedal
Started by irmcdermott, August 05, 2013, 05:21:40 PM
irmcdermott
Anyone have a diagram for something like this? Where you can only choose A or B or C and no combinations? I've done some searching and have com up empty. I'll sit down tonight and try and diagram it out, just wanted to see if I could save myself some time. Thanks.
ThePastRecedes
It's probably two of these in series. Output A fed into the input of the second.
I build stuff for myself, sometimes I do 1 offs, I label them as HornBlende Audio.
Have you looked at Beavis audio?
Yeah, I agree Ian. It looks like it's just two AB switches in series, with switch 'c' choosing between the other A/B switch, and the C output.
irmcdermott
Thanks guys. That's exactly where I was heading, just hadn't drawn it out to get my head around it.
irmcdermott
Sorry for the crude drawing. I didn't put any grounds or LEDs in, but the signal routing is essentially this, right?
ThePastRecedes
Whats the reason for those extra loops on the second 3pdt switch? are you planning to ground the inputs or something?
Other than that it looks perfect!
irmcdermott
Yeah, so just like the Beavis layout, those loops will get grounded out.
ThePastRecedes
Looks good to me then  :)
