apparently the solution sometimes really is a bigger hammer ... or poltergeists
Started by midwayfair, August 05, 2013, 03:38:58 AM
I had a pedal go microphonic on me ... Tried literally everything I could think of but toughing the circuit board or jostling the pedal kept bleeding into the audio. I actually pinpointed the spot in the circuit where the noise was coming from, and despite removing every component connected to a voltage source, the sound wouldn't go away ...
So I soldered it back together, reflowed all the solder, noise was still there.
Since I couldn't think of anything else to do, I decided to hit the pedal on the rug.
Noise went away.
Wtf.
Well, assuming that it meant there must be some sort of loose connection or something, I tried to make the noise reappear. Nope, nothing. I tried dropping it on the floor again, tossed it around into the sofa, shook it, everything. No noise. It's like it was never there.
Now I'm scared of the pedal because clearly it's alive and conscious and out to get me.
Can't sleep, pedal will eat me ...
Matt
Gene Simmons is behind this I'm sure of it!  (Wondering if anyone will get the reference)
Matt
Or worse, start a revolution with all tour other electronics in tow
Haberdasher
if a sirloin starts inching across your countertop call me immediately and i'll bring a flamethrower and loaded baked potatoes
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
ch1naski
I used to kick my Thomas Crybaby's whenever they acted up. Nine out of ten times, it worked.
Short term, at least. :P
Sent from my Nexus 7 using Tapatalk 2
one louder.
To quote one of my engineering mentors: one kick is maintenance, two kicks is abuse.
Stomptown
And I thought I'd tried everything! Time to pull out the box of fail and my biggest hammer!
Gledison
Thats what happened pinpointing something! U have just re discovered the voodoo on it pedal! 😜
DutchMF
Quote from: lincolnic on August 05, 2013, 04:21:43 AM
And three kicks is usually enough....  ;D
Paul
