How to get more mids in this circuit
Started by mjcyates, August 04, 2013, 12:14:16 AM
mjcyates
Hey guys I just built a clone of the Rockett Pedals Animal overdrive using the layout at tagboardeffects. The pedal sounds great. I would just like to add some more mids to it. Any easy tricks to achieve this in this circuit?
http://1.bp.blogspot.com/-IAU5PRSmY-4/UfL_EF_JiQI/AAAAAAAAFyk/9cqWBAXNd3A/s1600/Rockett+Pedals+Animal.png
mjcyates
oldhousescott
Not without adding in that second op-amp stage. Check out Brian's Sparkplug project for a circuit with bass and mid eq. Alternately, you could use that second stage to make a gyrator and, coupled with a cap and resistor, make a mid boost circuit.
mjcyates
alexradium
Just turn down bass and treble to taste and pump up gain and volume,there you have it.
Inviato dal mio Galaxy Nexus con Tapatalk 2
mjcyates
Tried that, not really what I am after.
