mudbunny civil war ver.sustain problem help!!
Started by glout, August 02, 2013, 09:38:32 PM
glout
I made the mudbunny civil war version and used the 2059 instead of the 2058 and now when i roll back sustain it grits bad and as i go further back i loose signal completely
When i roll up sustain past 1/3 it works fine till end.
Is the use of 2059 need resistor or cap change that is the question.
Bob
Can you be a bit more specific? Do you mean the 2SC2059?
Chances are that you need to check the datasheets and make sure you're using the correct pinout.
