Screaming Pacifist (Now with Sound File)
Started by billstein, July 31, 2013, 04:41:52 AM
billstein
Quote from: hammerheadmusicman on July 31, 2013, 11:23:41 PM
Also, how do you use the two pedals together? Stack them? Low gain on the TS? Did you experiment with the order of the two before boxing up?
Sorry for all the questions! Just curious :)
My initial plan was to put an order switcher in but I ran out of time because I wanted to get it into the contest. Maybe I'll add it later. I've got another Green Bean I've built so I can put that after the Zen drive and see if switching the order would even be worth it.
To be honest I'm not really sure exactly how I'll use it. I've only had a few minutes to play with it and was excited about the possibilities. Just a ton of sounds in there.
billstein
Quote from: hammerheadmusicman on August 01, 2013, 12:01:03 AM
Ahh, what about a ton of clear coat?
I thought about that too. I did put a lot of the Satin finish on it but it still seems vulnerable. The good thing about this is if it gets beaten up, replacing it would be fairly easy. Just print a new one out and stick it on.
