Zero Point SDX, help needed: Why the delay distorts when strumming loud?
Started by Teddy, July 27, 2013, 08:55:34 AM
Teddy
Here i go again =)
attachment long_delay_2.zip
contains long_delay_2.mp3
Is it just me, but do i hear a lot of sizzling noise on the repeats?
Thanks,
-Teddy
kothoma
OK, I can hear the hiss. Don't know how much is normal.
Is it the same in every filtering mode?
It shouldn't. Depending on the selected filter more or less hiss should go away.
Teddy
#47
Yes, the hiss is the same on every filtering mode.
Hiss goes away a little, when delay is shorter.
I'll try probing to find out when the hiss starts.
- Teddy
Teddy
Well, the odd thing is, that the hiss is louder when guitar signal is present while the delay sounds.
Like, playing a chord and holding it, instead of quickly strumming and muting strings.
Any ideas?
Also, when delay is turned down, the hiss is less audible.
Thanks,
-Teddy
kothoma
There's no hiss on the dry signal with mix all the way down?
The hiss is on the wet signal (the delays) only?
It is stronger while there's also a dry signal?
Teddy
Dry signal is good, with mix down. No hiss, when mix is all the way down.
The hiss is on the wet signal only (delays).
The hiss is stronger when there's also a dry signal.
Thanks,
-Teddy
kothoma
Quote from: Teddy on July 28, 2013, 10:56:30 AM
But the hiss is already in the dry signal (after the mode switch or at the mix pot)?
Teddy
No hiss in the dry signal.
-Teddy
kothoma
Oops, sorry, wanted to ask:
But the hiss is already in the wet signal (before or after the mode switch or at the mix pot)?
So we can rule out the dry path and the mix stage.
The hiss comes from somewhere in the wet path.
Does this his go away with lower guitar levels?
The dry signal always also goes into the first delay line.
So the hiss could come directy from within the first PT.
Teddy
I'm not sure, if the hiss is present before or after the mode switch or mix pot.
(i will probe it today)
Hiss doesn't go away with lower levels.
Thanks,
-Teddy
I don't see voltages anywhere in this thread.  Posting voltages of the IC's may possibly help.
Josh
Teddy
Teddy
#57
Hello!
One more audio clip.
long_delay_noise_3.zip
Delay = MAX
MIX = MAX
This clearly shows the issue.
When delay is backed down, to almost minimum, then there is almost no noise.
Oh by the way, the distortion exists before the filtering section, probed it.
Thanks,
-Teddy
Teddy
#58
Voltages of IC3 measured against GND
1 VCC = 5.02V
2 REF = 2.436V
3 AGND = 5.5mV
4 DGND = 5.5mV
5 CLK O = 2.997V
6 VCO = 2.436V
7 CC1 = 0.690V
8 CC0 =0.690V
9 OP1-OUT = 2.437
10 OP1-IN = 2.434
11 OP2-IN = 2.433
12 OP2-OUT = 2.433
13 LPF2-IN = 2.436
14 LPF2-OUT = 2.442
15 LPF1-OUT = 2.436
16 LPF1-IN = 2.436
Voltages of IC 2 measured against GND (they are essentially the same as IC3...)
1 VCC = 5.02V
2 REF = 2.439V
3 AGND = 5.7mV
4 DGND = 5.7mV
5 CLK O = 3.043V
6 VCO = 2.436V
7 CC1 = 0.685V
8 CC0 =0.690V
9 OP1-OUT = approximately 2.45volts, every pin from 9 - 16
10 OP1-IN =
11 OP2-IN =
12 OP2-OUT =
13 LPF2-IN =
14 LPF2-OUT =
15 LPF1-OUT =
16 LPF1-IN =
Teddy
Well, if there's anything more that comes to mind, that would help with my build of ZPSDX,
i'd really appreciate it.
Thanks,
-Teddy
