Non Madbean, Shoot the Moon Tremolo
Started by hoodoo, July 26, 2013, 07:17:34 AM
hoodoo
G'day to all, Matt here. This is the latest build, Culturejams Shoot the Moon Tremolo. Very nice tremolo, quiet and musical. This is my first attempt at envirotex, and it worked out pretty good, not as shiny as i would have liked, but i was stressing about wet sanding/polishing it and maybe f@#king it up, so i left well enough alone  :) next time. A couple of build issues, LED on board in backwards to start with, square pad is not always the anode side, i found out, and Josh's new 3pdt board has + and - pads next to the LED pads and guess where i soldered the LED after i had hot glued it in  :P. And maybe i've been spoilt with the great PCB's available around here, but board mounted pots definitely rule!
Take it easy, Matt.
This looks great, Matt...and I know what you mean about being spoiled to MB boards! Having to wire in pots seems like such work now.
hoodoo
