Stage Fright over driving
Started by LaceSensor, July 13, 2013, 12:06:44 PM
LaceSensor
Hi
Built up the stage fright board today
Changes were the 30k resistors were 33k, and the 3k was 3.3k
Otherwise as stock
No matter where you set the trimmer this thing is clipping
Is this symptomatic of dodgy  LM13700s?
I had 4 and Ive tried the other in all permutations and I still get distortioin so I dont think its them
Ive tried other op amps, same.
Ive tried other transistors, same.
Reflowed all joints, same
I got everything from reputable sources.
thanks
https://www.gigaheartsfx.com
instagram @gigahearts_fx
Nope, it sounds really good. Either there's a wrong component or bad ic's have you checked your voltages? I'd start at the jack just to see I the jack itself is screwy or a power supply is starting to go south on you.
Scruffie
Voltages.
The 13700 don't have that higher headroom and can go in to nasty distortion if pushed too hard, what pickups are you using?
That trimmer is less about 'biasing' as it is getting the correct current/wave out of the LFO, although with too higher current the OTAs do play worse.
Those 30k & 3k are in said current network and may make a difference...
Works at Lectric-FX
LaceSensor
Quote from: Scruffie on July 13, 2013, 03:32:52 PM
Voltages.
Oh, jazzmaster p90 style or an electro acoustic...
Too hot an dbothered now will do later..
It's not the power supply or jack or any of that
I will change those resistors for the right value then...
