Nautilus DPDT PCB Mount Switches
Started by zapme, July 12, 2013, 06:07:32 PM
zapme
I'm trying to find DPDT On/On PCB Mount Toggle Switches with the right spacing to mount to the board.  I ordered the wrong ones from mammoth.  :(  Anyone know where to find these? Thanks
hammerheadmusicman
i got the ones i used in mine from Tayda.
I play Guitar, and Build Stuff..
BLMS has them too, that's where I've gotten several as well as Tayda
Stomptown
If you are in the US I would just hit up the local radio shack. It will. Cost you less fan paying for shipping and be quicker. I used them in mine and they worked fine...
zapme
Thanks for the tips guys.  I checked radio shack today but had no luck. Looks like online purchase is in order.
zapme
well after looking on tayda they only have through hole solder tabs, no pcb mount ughhh,
Is this what i need? Its a bit pricy but the only one i've found.
http://buildyourownclone.com/switchtgdpdtpc1-1.html
DutchMF
The Nautilus board (and I believe all Madbean boards with board-mounted switches) is designed to accept the solder lug switches, so back to Tayda and buy some of these: http://www.taydaelectronics.com/electromechanical/switches-key-pad/toggle-switch/mini-toggle-switch-3pdt-on-on.html While you're there, you can stock up on jacks, pots, switches and all the passives you need! I think it was just a case of us mis-understanding what you meant.......
Paul
Stomptown
Quote from: DutchMF on July 13, 2013, 07:42:39 AM
Paul
This! I should have mentioned that the ones I used from radio shack were solder lug not PCB mount
zapme
I went back to radioshack and pickup the switches.  Thanks for the clarification that the solder lug switches would work.
