Loophole - pretty much acting as it pleases...
Started by Cortexturizer, July 08, 2013, 12:50:11 PM
Cortexturizer
I have problems with my loophole. It pretty much acts as it pleases.
All the controls work as they should.
"Both LEDs are on when I record which is OK [used a momentary switch to record] then when I press Play, it plays the loop but it plays the whole available time in the ISD chip! Not just the time I used to record a loop, everything. That, and when I record some more, it records over the last recorded loop and if the new loop is shorter, then when it finishes the old one just continues!!! Like a cassete tape on Walkmans haha.
And it does that, only ONCE, so, it's not looping, it's just playing the recorded stuff once. What a bummer.
I used the ISD1020AP chip.
The detune feature is also non-working."
I posted this yesterday on another topic, but of course it's better to open a tech help topic.
So that was yesterday...TODAY - it worked as it should, in regards to looping, it DID loop but at the end of every loop it kind of played a discharghing kinda sound as well, some white noise snippet of sorts. Weird.
And THEN, I decided to record total silence for a minute. After that, I couldn't get the pedal to work right. I couldn't record anything nor play anything.
Weird.
Uber weird. Any ideas to what may be wrong?
Would you guys go through my voltages if I post them?
