Zombii Fuzz Drilling template
Started by Gledison, July 03, 2013, 07:35:02 PM
Gledison
Hey mates,
anyone has a 1590b drilling template for the Zombii ?
thanks in advance
This is pretty close (right click and save, it's PSD format): http://juansolo.demon.co.uk/stompage/pstemplates/Zombii.psd
That's specifically for a Camden Boss enclosure though so it's slightly the wrong shaped border for a 1590B. The pot spacing should all be right though.
SmoothAction
Use graph paper. Take your time with it. Make a graph paper "shell" taped to the enclosure, mark your points for pots/switch/jacks/led, then use a hammer and nail to dent those points you made, then drill them. I use that method for every pedal I do, it always comes out even and nice. Plus if you're careful you can use the same template over and over. DIY.
Gledison
Thanks guys.
hey juansolo your design is pretty cool!
I've found a 1590b template and I will use yours to have perfectly aligned the pots.
I don't wanna a make a template myself now because I've just started. it will be my second build...
maybe in a near future..
cheers
