Loose Screws
Started by pickdropper, July 02, 2013, 01:39:29 PM
I built a couple of screwdrivers, one for me and one for a friend of mine.  I am determined to have one of that circuit on every pedalboard I have.
The copper/silver one is actually a salvaged enclosure.  I etched the raw enclosure, but the laser engraver was misaligned, so it was shifted about 0.045" to the right.  I etched the silver plate and used that instead.  It actually looks nicer than the original enclosure would have if it had been properly aligned.
The green guts were unfortunately messier due to that absolutely unnecessary addition of a battery snap.   ;D
That silver and brown/copper one just speaks to me.. looks awesome. What kind of transparent paint is that? I have got similar results with RC car shell paint in the transparent colors but nothing like that brown/copper one. Looks beautiful.
Beautiful every time, Dave. That design always looks particularly killer on silver, but it's interesting to see it reversed on the black, too.
I'm surprised Smallbear can keep stock of those knobs considering you use them on almost everything. :)
Quote from: selfdestroyer on July 02, 2013, 01:43:24 PM
The enclosures are painted by PPP.  I think they are actually called Transparent Green and Transparent Copper, but I'd have to check.
The silver one is a two-tone acrylic plate I've been messing with.  The only downside is that it tends to curl, so I had to attach it with strong double-sided tape.  Then I clamped it flat and ran a bead of low viscosity (250 CPS) epoxy around the edges to hold it in place permanently.
Quote from: midwayfair on July 02, 2013, 01:44:29 PM
Thanks Jon, I was trying a couple of different things with these to see what I liked.
And yes, guilty as charged with the knobs.  I think the silver classes everything up.
Beautifully done, as always.
slimtriggers
Man, those are great!
croquet hoop
It's funny how you manage to make each new build look better than the last. Great job as always, I love those faceplates.
Have you ever considered using the slightly bigger version of these knobs for your 125B builds? (the same Skreddy uses if I'm not mistaken) Not that there's anything wrong with these ones, but I'm curious.
Quote from: croquet hoop on July 02, 2013, 02:27:41 PM
Yes, I did use them on a Lunar Module build a while back.  I agree that those look good too.
Dave, what are you using for transistors in those?
Quote from: midwayfair on July 02, 2013, 03:05:31 PM
They are both AC176 with a gain between 80-100 and a decent bit of leakage.
ch1naski
That's what i used in mine, those sound super duper killer in this circuit.
What is the through plated board I see there?
Sent from my PG86100 using Tapatalk 2
one louder.
Quote from: ch1naski on July 02, 2013, 08:27:06 PM
It's a PCB that I laid out a while back.  It's sized for 1590a, but obviously works in larger enclosures as well.
fendman
QuoteThe green guts were unfortunately messier due to that absolutely unnecessary addition of a battery snap
:o Come on Dave...messier...that is not even in your vocabulary. Myself and everyone that see these builds are just drooling.  Jimilee I believe is catching you up though,, me thinks you are giving him guidance.
Absolutely mint  :P
Mike
wstimson
Quote from: pickdropper on July 02, 2013, 08:39:53 PM
*cough* ...A PCB you should totally make more of... *cough*
