2 effects in 1 box
Started by Guitafuzz, June 05, 2013, 04:04:28 PM
Guitafuzz
  Hello guys, I'm planning to build a pedal 2 in 1, combining a marshall Bluesbreaker and the rat, what kind of enclosure recommend me for a pedal 2 in 1,  also want to include the effect order switch. Thanks in advance
GermanCdn
6 knobs, three switches minimum, you probably want to go with a 1590BB width wise, or a 125BB which will give you a whole lot of room to work with.
wstimson
Those aren't huge boards, so with some proper planning a 1590BB will work just fine.
Guitafuzz
TNblueshawk
If you want to error on the high side you can also get a "tall" BB enclosure. I like to use those since I suck at keeping things neat etc...
John
A 1790 is also a good choice.  Same height as a 1590BB, but just a bit bigger for more wiggle room!
Josh
