honeydripper 3p4t rotary switch
Started by mcosmai, June 04, 2013, 12:43:23 AM
mcosmai
I'm just about to solder in the 3p4t switch rotary switch on the Honeydripper.  I notice that numbers and letters on the switch, which I purchased from Small Bear, don't exactly exactly line up with the numbers and letters on the board (pin 6 on the switch is going into hole #7 on board).  It fits perfectly this way and doesn't fit any other way.  Has anyone else noticed this? Do I have the wrong switch or is it just an error on the letters printed on the board?
gingataff
I didn't notice it with my build, I was more concerned with the lining up the A B C.
Just make sure you soldered it onto the correct side of the board  ;D
mcosmai
Yes realized I had it backwards. Too many beers on the workbench ....
