Tube amp building
Started by atreidesheir, May 21, 2013, 12:08:59 AM
atreidesheir
A colleague has heard my pedals and has approached me about building him a champ 5f1 amp over the summer.  He will supply the parts.
I am not an amp builder.  Ruby doesn't quite count.
Is it going to be smarter to buy a kit or use the BOM and source the parts myself?
I do not need a chassis or cabinet.  I can build the can and my dad is a retired pipefitter and will weld me a  great chassis.
drezdn
Personally, I like starting any new area with a kit, but if you're really comfortable with a schematic, it's worth a shot to try it without.
Depends on who the kit is from. Mission Amps and Mojotone have good reputations. Also, do NOT use the deathcap from the original, use a proper ground with a 3 pin plug for the mains. Run through it with a multimeter checking for shorts to ground.
Also, consider purchasing a chassis. They come all nicely chromed with white lettering from mojo :)
pryde
This guy has the best F51 and 5E3 kits. I have built a few of both for myself and others. Get in contact, Dave is a great guy and is a frequent on the TDPRI forums. He will give you full support all the way through.
http://www.boothillamps.com/
atreidesheir
Quote from: pryde on May 21, 2013, 12:19:09 PM
That was the most impressive site yet for kits.  That may well be the way to go.  I have sourced the two transformers from MOuser. btw
pryde
Quote from: atreidesheir on May 21, 2013, 01:26:30 PM
You might want to hold off on the iron until you talk to Dave (if you go that route) The OT and PT are essential to a proper sounding build. ClassicTone are great in these amps for the money.
Rockhorst
Bought an Ampmaker.com kit last year. Very happy with it.
Blues Healer
I built a Mission Amps 5E3 several years ago, that turned out great.
I'd recommend getting a kit for the convenience. Most kits should actually be a cost savings as well. I'd also get the chassis -- there's more to a chassis than just bending metal. They should be properly silk-screened and chrome plated.
I'd be partial to MojoTone, since they've been around quite a while. Weber also has kits, but last time I checked, it seemed they used some cheap parts. (Don't quote me on that.)
I'd also recommend looking into an upgrade to Mercury Magnetics transformers. It may not make economic sense on a Champ build, but on any larger amp, it's worth it -- good transformers are the often unseen critical ingredient for great tone.
"music heals"
I'd recommend Heyboer or ClassicTone over Mercury Magnetics -- MM seem to automatically put their price as being 400% of anyone else, which to my mind is way past diminishing returns and straight into corksniffery audiophile. (The mojo stuff is mostly Heyboer, IIRC.)
I use Magnetic Components iron on everything now.  Price is right, built like a tank, spec sheets on every transformer available from the manufacturer.   Mercury won't give you a spec sheet before you plunk down a heap of cash on their iron/hype.
jighead81
If you don't need the chassis or cab, check out the champ kits at
http://www.triodeelectronics.com/5f1kit.html
They use the classictone trannys and they're my favorite.  I built my first vibro champ from them.  They were very helpful through emails and helped me get it running.  I ended up with a handwired turret board vibro champ with zero hum that I still use years later, and it takes pedals very well.  good luck
atreidesheir
There are a couple of good options here.  I will let you guys know which is selected.  I am kinda getting the itch to do this now. ;D
+1 on the kit idea.  I sourced my own and while it taught me how to make eyelet boards it's not really any cheaper than your average kit.  Kit does a bit of hand holding when you need it.
I've used a lot of Mercury Magnetics trannies for repairs, especially in older American-made Crates, where it was impossible to find a good match elsewhere.  Very nice iron but crazy expensive.
I'm a real big fan of the Magnetic Components stuff.  Really well made and great folks to deal with.  Plus they're local for me (they're in the Chicago area).
Check out http://store.triodestore.com/5f1kit.html and you get the best of everything.
