VTL5c3 -vs- VTL5c3/2
Started by mtharper928, May 23, 2013, 01:16:04 AM
mtharper928
So although I have experience in electronics, I am relatively new to making pedals and was putting together my purchase order at small bear for the Aquaboy DX a little in the night and accidentally purchased the VTL5c3/2 instead of the VTL5c3.  I tried looking at the data sheets but unsure that the 3/2 can be used, due to the extra lead it has.  Anyone know a solution, or do I just bite the bullet and re-buy it?
Side Note: Just finished building my first pedal yesterday (BYOC Octave Fuzz) and I am officially hooked!  Thanks to everyone to making this process easy!  Looking forward to many future builds!
I think you should be okay as long as you connect one of the outer leads (on the resistance side) to the center lead. The 3/2 version is like a potentiometer on the resistance side (instead of a resistor). So the same rules should apply. But I'm like only 97% on that.
Quote from: mtharper928 on May 23, 2013, 01:16:04 AM
no build report or pics or audio or anything???  You are new, ha! Welcome to the club mang!
mtharper928
Thanks for the input!  Attached are the data sheets.  No build report or audio as she is still getting some solder TLC.  I was just making sure before I wired her all the way up.
Just think of it as 2 LDRs with a shared middle lug against the LED so use the middle and either left or right lead and ignore the other.
However... it does seem like a slight waste to do so, you may find you're able to trade it for the correct vactrol with someone especially as it costs a few dollars more.
mtharper928
AHH, gotcha.  Thanks a lot!
