Stage Fright - 6 Yes, 5 no
Started by GermanCdn, April 30, 2013, 04:55:46 PM
GermanCdn
So I built up the Stage Fright last night, and after remembering to jump CV after the first test (I swear I turn completely into a cave man when things don't fire up first time), everything sounds awesome with the DPDT in the left hand position (6).  However, in the 5 position, it does not sound like the demo, it's there, but it's barely audible, and it's mostly dry signal coming through.
Given that it works in the one position, but not so much in the other, methinks it's a POS switch, but before I go about desoldering a board mounted switch (my second least favourite desoldering job out there), is there any other likely culprit?
At work so I can't post pics right now.
Try audio probing around the switch/IC4 area to see if you have output. That would tell you if it is the switch.
