Mangler
Started by Jyka, April 26, 2013, 06:25:13 PM
Jyka
Hi,
My future project is to build a Mangler cause i recently have 2 Nkt 275 with hfe Q1 : 120 and q2 hfe : 80, do i have to change the trim with for a 10k with 3k resistor ?
thank you so much
pryde
Per the build doc use a 20k trim pot to bias the transistor ( around -4.5v).
If you want to use a fixed resistor, measure the trim pot R after you bias and replace with an equivelent resistor value.
However, you will allow yourself more tweakability if you just the trim pot in there.
