Low Rider
Started by lljoepj10, April 19, 2013, 01:25:27 PM
lljoepj10
Hi There
Since I am new to Madbeanpedals.com , i wanted to ask you question about the Lowrider pedal.
http://www.madbeanpedals.com/projects/LowRider/docs/LowRider.pdf
I've ordered the PCB , but i noticed the R55 is a 160 K resistance.
I could only order 150 K or 180 K .
My question is :
what posibility is better ?
-150 K
-180 K
or to couple a 150K and 10K ???
Sorry for the bad english btw :P
Greets Joep
gingataff
I think the 150k would be ok, there are some mods that lower the value of this resistor but you could socket it and change it later if you need to.
Sent from my SC-02B using Tapatalk 2
stecykmi
150k will work just fine, this will very slightly increase the maximum volume of the 1 octave down sound. it will still be fully controllable by the pot.
rullywowr
You could always use a 150 and stand it up in a "teepee" with a 10K and be right on the money.
njkke
#4
You can try a 150K + a 25K/50K trimpot... ;)
