silly mini build question
Started by octa805, April 24, 2013, 05:00:23 PM
octa805
I have one of pickdroppers minimuffs I just completed.
stuffed that turkey into a 1590A.
I couldn't get it to work at first. Just audio-probed it and I get the full fuzzy fun signal coming all the way through the board, at the footswitch and even at the out jack when I put my probe on it.
I crammed the jacks in there so tight and they are not the enclosed ones so I had to do a bit of bending to get them to fit but man, it's real close.
is it fair to assume that when I put the plugs in the jacks and they expand slightly I'm likely getting some metal on metal contact which is why the signal will not come through the amp even though it's reaching the output jack per my audio probe?
pics would help. will do it when I'm off work.
thanks!
GermanCdn
Yes, you could be grounding out the leaf against the body.  Rotate your jacks so the leafs are parallel to the top of the enclosure and opposite each other, and you should be all right.
octa805
I'll give that a whirl. Thanks.
I have them so tight in there next to each other, pots & footswitch it's hard to even see if they are grounding when all plugged in
Yep, something's shorting there. Electrical tape is your friend. Certainly when there is a chance in a 1590A that a pot might spin and short I've put tape on the 'danger regions' of the enclosure. Likewise under the board above the pots if it might snag the jacks or on the lid if the can of the transistors might short against that. They're tight little buggers!
Does it work if you open the box and pull the board out so it clearly isn't touching anything?  If the wire lengths allow it, that would be the first thing I would try.
I'm generally a fan if closed jacks for mini builds.  They are usually a bit more expensive, but they provide a good mounting surface for the PCB.  I use them in all of my mini muff builds.
octa805
Quote from: pickdropper on April 24, 2013, 06:25:56 PM
I haven't pulled it out yet but that it works w/ the audio probe on the output jack is good enough for me to validate it as ok.
This is my first time w/ the open jacks. Tis a bit of a bendy, weird mess in there right now. I for sure need to tape off quite a few things. Hoping that does the trick.
Thanks everyone!
(oh yea, then I'll have to make sure I can stuff it all the way in there!)
octa805
put some tape in there
bent some stuff
totally fixed. thanks everyone!
now I have to make it fit in the 1590 w/ the lid on. uh, yikes. mostly cuz I socketed the trannies.
built it to 71 triangle specs. I really like it but it seems to be not as heavy in volume as my standard Big Muff. Might just be the trannies. Playing with those does quite a bit.
anywho, I'll be swapping out trannies now. weeeeeee!!!!!!!!!
