sub for K246 gr jfet?
Started by guile, March 30, 2013, 12:35:39 PM
guile
Building an overdrive which needs an K246 gr Jfet. Are there any subs for it?
Haberdasher
if it's for the maxon od820 I etched for ya, it's just an input buffer I think.  just about any jfet will do there.  you'll definitely have to study the datasheet for the jfet you choose and compare it to the schematic to  make sure the pins are in the right order.  a lot of those toshiba jfets like the 2sk246 have sgd pinout, so you may have to twist a couple of the legs around to get it to match up.
the toshiba 2sk117 tayda carries may have the same pins if you have any of those handy...
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
