Thunderpuss pop
Started by Guitar Master, March 21, 2013, 03:04:39 AM
Guitar Master
Hello,
I know that it says in the build guide that their will be some popping and I wired it up the way that the diagram shows, but there still is significant "pop" when engaged. Is there any mods/fixes that would fix this?
Thanks in advance!
gtangas
#1
The second pedal I build was a thunderpuss... No pop
As we discussed on the sea urchin pop post use a resistor from the fx output to ground.
Preferred doing that on the board (lesson learn Jon)
start with a 100k resistor but you can go to values like 1M
But as the value increase more resistance is applied.
You may want to try to change the footswitch (mechanical noise)
But this is a suggestion from a devoted Noob
