can you use a battery snap with a mono jack?
Started by danwelsh, February 22, 2013, 01:59:19 AM
danwelsh
Hi, just wondering if there's a way to hook up a battery snap with mono jacks....I just completed a build but want to add a battery snap and low and behold i forgot to order jacks so i had to pick them up at radio shack and all they had was mono jacks...i realize i can hook one up to the lug on the the 9v jack and the ground on the mono jack but will this mean that i have to disconnect the battery every time i plug it in with a 9v adapter? Thanks in advance guys.
danwelsh
Okay but did you have to pull the battery when using a 9v wall adapter?
Nope.but this is just my experience,I've had no issues.
The stereo jack is used to disconnect the ground side of the batt when the pedal is not in use, basically so it lasts longer, otherwise it will be slowly discharging al the time.  The switched DC socket is the part that disconnects the +ve side of the battery when a power supply is plugged in, and that keeps the magic smoke from escaping
danwelsh
Okay, thanks for clearin that up 4 me.....battery snap after work today :)
Quote from: danwelsh on February 22, 2013, 11:18:08 AM
Just keep in mind that when you don't have a DC jack plugged in, your battery is going to be continually discharged if you use a mono input jack, regardless of whether or not an instrument cable is plugged in.
So if the pedal is always on your board and plugged in to your DC supply, you're fine. But if that's the case, why do you need a battery?
I would caution against using a battery snap without a stereo jack. You're just going to waste batteries and put heavy metals in the landfill for no reason.
/hippie rant
DutchMF
Quote from: culturejam on February 22, 2013, 02:04:42 PM
/hippie rant
Might be a hippie rant, but it's still true! I strongly suggest you use a power supply instead of a battery snap, it's all in the little things that make a big difference! Oh, if anybody is interested, I bought 10 battery snaps from Tayda on a crazy wim, as they are so cheap. Realizing I'm not gonna use them, ever, they're up for grabs....  ;) Will repost in the buy/sell/trade area!
Paul
danwelsh
Ill just take the battery out when not in use......reason for this being i only have so many power outlets in my home,dont play gigs and just built my 2nd pedal and ordered 4 more builds.....
danwelsh
Or better yet ill just wait until i get a stereo jack
pedalman
Quote from: danwelsh on February 22, 2013, 03:54:41 PM
lol... get a generator to power your pedals, then just turn up your amp !
