Sourcing waterslide paper
Started by addshoe, February 21, 2013, 03:12:12 PM
addshoe
Where do you guys buy your paper? I ordered some off ebay last and it was a little pricey but best I could find at the time. Any tips?
Haberdasher
I've never used any, but I've heard several people talking up a store called papilio
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
Stomptown
I found the papillo brand on amazon for a pretty decent price. There are different kinds out there. I personally prefer to use the kind made for laser printers over ink jet...
addshoe
Thanks for the replies!
I used inkjet for the first time the other day and didn't like that I had to spray with clear coat before applying. Is it true this step is not required when using laser printers?
pryde
Not sure about laser and clear coat but for inkjet waterslide I have always used the stuff from pedalpartsplus. I have tried a few different kinds and their stuff seams to work best for me. However, YMMV
Usually 1 simple coat of clear is enough to seal the ink and provide added rigidity to the material when applying to the enclosure
Mike B.
Look on Amazon. I forget the seller, but there's a store that sells the Papillio brand decals in various quantities.They have the clear and white. If you just need one or two sheets, PPP or SmallBear both have them.
I order from eBay also, it's hard to find for less than a dollar a sheet
hammerheadmusicman
this is where i get mine, it is UK though, it's £10 for 20 A4 Sheets. If you your struggling to get it.. not sure how much shipping would be.
George
Hangingmonkey
Quote from: addshoe on February 21, 2013, 04:54:01 PM
Shouldnt need it for laser printers as the toner is like plastic and wont smear in the water but i find that a generous coat of clear on the decal gives it strength and stops it from ripping, especially if you do a lot of adjusting
fish22
Quote from: Stomptown on February 21, 2013, 04:34:25 PM
+1
Hi, my name is Wyatt.
