Low Profile Stereo Jacks - TRS?
Started by hagcel, February 16, 2013, 10:57:53 PM
hagcel
Hey,
I'm working on boxing up a ZPD but I can't seem to find any info on the the low profile jacks, which is T, R, S? They are numbered 1, 2, 3...
Google isn't turning anything up.
Thanks!
hammerheadmusicman
i can't remember off hand, but get brian's 'baby board build guide' you can see the numbers on his in one of the pics, and i worked it out from there..
good luck!
George
Lay the jack on its side with the lugs facing away from you and the hole to the right. The top lug on the left is the tip.
hagcel
#3
Ah ok.
I got it to work. I had to ground both the input and output jacks to get any signal to pass and ground the board to the enclosure to get rid of some hum and clock noise from the mod section but now it's dead quiet and sounds great!
