2 Ch TB Looper + Order switcher
Started by guitarplayer08, February 15, 2013, 02:15:24 AM
guitarplayer08
Guys,
I am sorry if my question are dumb. I have used the search function and found this diagrams of effects switcher:
http://www.madbeanpedals.com/forum/index.php?topic=4169.msg37019#msg37019
My question is, will the two 3PDT switches on top work like true bypass channels? I'm looking to build a 2 channels true bypass looper to make my BOSS pedals true bypass but I would like a third 3PDT toggle to switch the order.
If there are diagrams of this somewhere, I'd greatly appreciate it.
Thank you
guitarplayer08
Thanks for the reply, but wouldn't having only one switch limit me from turning on and off (true bypass) each individual channel?
DutchMF
The diagram in your first post does exactly what you want. I've messed around with that setup some and it works like a charm!
Paul
guitarplayer08
So when the two 3PDTs for the 2 effects are turned off..I will be running just dry signal to the amp correct?
Nice! Thanks guys
