Egodriver and clipping
Started by gtangas, February 09, 2013, 08:27:51 PM
gtangas
Finished a minutes ago the Egodriver
Everything works nice but I can't hear any difference when engage the clipping mod
This is my first pedal with led clipping so sorry for the Noob questions...
Should the leds turn on when clipping on?
I used 5mm red leds
gtangas
For clipping I can only use 5mm leds? Or 3mm will be Ok as well?
From what I've read, in the clipping diode position you can use any diode your heart desires :)
You can even use things that are not diodes but can be wired to work as them, like 2n7000's.
gtangas
It was the led  :D
I tried with 5mm yellow and it worked. The light from the leds was to vanish so i swaped by 3mm red and the result is much better
Now I can hear the diff... I like it!! I hum hum  ;D
pedalman
give it a socket and play with it
