Firebomb Troubleshooting - where to begin?
Started by camsna, December 12, 2010, 01:13:17 PM
camsna
So - my build is done and I have a few problems. They are:
1 - Neither LED lights
2 - When the 2nd SHO is engaged, there is no volume unless the volume (middle) pot is turned all the way up
Gut shots may come about eventually, I just won't have time to snap any until the end of the week. So, hopefully we can brainstorm without them ;)
Thanks again!
LED doesn't light means either the LED needs to be reversed, or it is not wired properly to the switch.
Not sure about #2. Does the second one work if the first one is off?
camsna
Quote from: madbean on December 12, 2010, 02:03:02 PM
Yes. #2 does work - as long as the volume is dimed.
I'll check the LEDs direction. I triple-checked them before putting them in, but I may have still gotten it wrong.
Thanks!
camsna
Forgot to update, sorry 'bout that!
1 - LEDs were in backwards. Derp. Thought the square pad denoted + lead. Boy was I wrong.
2 - Fixed a couple of solder joints that I think were causing partial shorts.
3 - Pedal is (now) built and works perfectly. On its way to my little brother for Christmas!
Thanks for the help!!!
Cam
camsna
Oh yeah - PS - the completed build is in the Build Reports section. :)
