EHX Holy Grail Reverb- Whine
Started by sirbergersworth, June 24, 2013, 04:29:42 PM
sirbergersworth
Anyone know of a mod to stop the crazy whine I get with my EHX Holy Grail Reverb?
It works fine in the effects loop of my tweaker15, but my vht special 6 head does not have a loop and it whines like crazy when in front of either amp.
Any ideas?
"Comes a time when the blind man takes your hand, says, "Don't you see?"
-Robert Hunter
Loztboy
Is it the big or small box? I have tested both, and the big box was a little more noisy, but no whine.
What are you powering it with?
sirbergersworth
Big box and powering it with the original power supply.
Sent using Tapatalk
-Robert Hunter
Check your power supply with a DMM. I had this issue and it ended up being the PS. I have the large box version also.
sirbergersworth
Thanks. I will check it.
What was wrong with the power supply?
Sent using Tapatalk
-Robert Hunter
Quote from: sirbergersworth on June 26, 2013, 09:13:49 PM
Sent using Tapatalk
Mine was not putting out enough voltage and it was starving the pedal.
sirbergersworth
Quote from: selfdestroyer on June 27, 2013, 06:49:35 PM
Sent using Tapatalk
thank you
Sent using Tapatalk
-Robert Hunter
sirbergersworth
My ehx power supply is rated 9v 500ma
I am getting 12.5 volts and 4.4 amps. Not sure but I think that equates to 4400ma?
So it could be putting out to much amps?
Sent using Tapatalk
-Robert Hunter
Quote from: sirbergersworth on June 29, 2013, 04:30:08 AM
Sent using Tapatalk
Sounds like you found your problem.
Effectsiation
Yeah that pedal is very power supply specific, various noise occurs if you somehow end up giving it something different than what it wants, at least in my experience.
sirbergersworth
Quote from: Effectsiation on July 03, 2013, 03:54:50 PM
I guess a new power supply is in order.
Thanks everyone.
It is funny that it doesn't whine when in the effects loop.
Sent using Tapatalk
-Robert Hunter
