How to tell if an IC is operable
Started by hoodoo, January 20, 2013, 10:41:22 AM
hoodoo
G'day to all, Matt here. Just a question for those folks that would know, might be a dumb question, apologies if this is the case. Anyhow, I want to know if there is a way to tell if an IC is in operable condition without placing it in a circuit. I have come across a range of second hand ic's, and am trying to determine what to build with what i've got, but don't want to build the circuit and then find that the ic doesn't work. Any advice appreciated, thanks, Matt.
DutchMF
The only thing I can think of is placing it in a board that is known to work, but then that board would have to be compatible with the IC in question. You could also breadboard a circuit that takes the IC you have and test in that way
Paul
jeffaroo
i seen some guy that had a testor he made i sent him a email with no responce
all i seen was 2 switches 2 leds and a wierd chip holder (pinch type like on a computer motherboard)
and a terminal strip on the side
Not enough germaniums in this world to complete my wish list !
jeffaroo
may be worth a try, but it will work a little better with a chiquita bannana sticker in the corner
hoodoo
Thanks for the help guys, much appreciated, Matt.
