[Non MBP] 22/7
Started by alanp, December 30, 2012, 12:19:21 AM
I wouldn't post this here, except that I don't think I've seen this kind of labelling done.
I engraved the lettering by hand with my dremel with the sharp pointy attachment, and then filled in the groove with indian ink (this stuff lasts for ages from just a tiny bottle!) So far, it's worked out quite hardy, as I did it before drilling and it lived through getting clamped up in the vice, and thrown around the desk while being finished up, all with NO clearcoat. I might have to use this method again, the only problem I had was misjudging how much room the washers and knobs would take up.
Most people will know what this is -- a Run Off Groove 22/7, an approximation of PI (aka a big muff), all done with NOT logic gates -- no opamps, transistors, or FETs were utilized in the making of this pedal. It is even more impossible to get a clean sound out of this than with the Chunk Chunk!
Hehe... You tattooed your pedal! 8)
What in interesting idea, using NOT gates like that!  I feel some reading coming on
Well done mate... clean is for wimps anyhow ;)
stecykmi
Quote from: nzCdog on December 30, 2012, 12:27:35 AM
it uses the same device as the snarkdoodle, aka tube sound fuzz. many people don't realize the cd4049 (the entire CMOS cd4xxxx series, in fact) was designed for digital logic circuits, it was not intended for analog circuits. the technology is outdated now, one would now design on programmable hardware, but it's possible to construct simple computers using those chips.
