Pedal Order Switcher
Started by mandrewbot3k, November 27, 2012, 04:02:52 AM
mandrewbot3k
I'm planning on building an egodriver rated for 18V and a fatpants and was going to run them in the same pedal using the external 18v of the fatpants. I was planning on adding a couple of features but one of them would be a 3pdt switch to change pedal order (with LEDs).
Here is my question....
Would it be more worthwhile to build one dual pedal?
or three separate pedals?
Seems that the second option would cost more, but me much more versatile. Any thoughts?
Andrew
(Formerly roflcopter)
hammerheadmusicman
I built one recently using a Quasar and a FatPants and I used a Rotary Switch to switch the order, also with a rotary switch, the pointer points towards whichever effect is first in the chain..
jeffaroo
just keep building those pedals and give each one a "letter" for its name. daisy chain them all together to look like this
IN----M-A-D-B-E-A-N----OUT
then turn them all on at the same time !    ;D
Not enough germaniums in this world to complete my wish list !
studiodunn
I use this diagram, as it works on a toggle as well.
mandrewbot3k
Andrew
atreidesheir
I always refer to the one by RDV posted at runoffgroove in the Double D project.
http://www.runoffgroove.com/dd-3pdt.png
jeffaroo
flipper makes my head hurt !
but it looks very cool. i wonder if i should put it with my fuzz / phase    :D
DutchMF
#7
This is my take on switching the order of two FX in one box. PM me if you need further clarification
Paul
(Forgot to attach the file..... Sorry 'bout that. Damn, this weekend business is hard work!)
studiodunn
Quote from: DutchMF on December 02, 2012, 07:10:41 AM
Paul
Thanks Paul. I wasn't sure we're I got it from.
jeffaroo
mandrewbot3k
#10
Single sided etch using Dutch's diagram. Havent done it yet.
I upped it to 300 dpi, so I think its a 2:1 scale.
I'm just starting with eagle. 20mil traces. Untested. S1 = SEND 1, R1 = RETURN 1, ETC....
EDIT: forgot to turn off the linework for the switch, UPDATED
Andrew
