dig dug and leaving out the wah
Started by gaffled, November 16, 2012, 09:58:00 PM
gaffled
Hey i was just curious if there is a way to leave out the wah part of the circuit so i can just use the sequencer part.  If so what parts can i omit.  any help would be much appreciated.  My schematic reading skills are only okay at best.  Thanks, mike
stecykmi
you can basically leave out everything based around Q1 (in the upper-left side of the schematic). if you want the "output" of the sequencer to be a voltage, use the output of R25. If you want the "output" to be a resistance, keep the vactrol.
good luck, this project is notoriously tricky.
gaffled
Thanks that helps a lot.  I figured I would just mess around with it and see if it would work.  I saw a thread about a dig dug 2 but I'm not sure if that will be a project or not.
