LOOPHOLE problem -- fixed--
Started by shay1510, October 24, 2012, 04:32:47 PM
shay1510
-------never mind, it was just a bad solder joint on 1 of the pots, thanks anyway. ------
Hey guys,
Need your help with the loophole project.
Built it, tested it once, it worked. the red light appeared when I recorded and the green light when I played it.
Now I've put it into an enclosure and it's not working right. I'll describe: when I press the record button both lights (red/green) are on (is that OK?), and when I try to play the loop nothing happens. Checked the connections - seems ok.
Someone got an idea?
Thanks.
*BTW I used a isd2560 chip and soldered legs 7 and 8 to 6 (ground) - like some1 suggested in another thread.
icecycle66
Man, I hate that.
I had a buzzing problem once.  I searched high and low for what was going on. Got really ticked off.
It was a grounding problem.
shay1510
I totally agree, but it feels awesome once you get it to work.
And that loophole thing is great btw.
A simple word of advice for all of you guys - use extra wire in your circuits!
you'll need it when the time for enclosure comes.
