is there a zombi drill template? if not how did you do it? here is my idea...
Started by jimmybjj, April 14, 2011, 02:19:09 PM
jimmybjj
...using the fabbed board on top on the enclosure and marking thru the center pot hole for each of pots. anyone got any better ideas. I going to try Photoshop but my ps skills are limited. I can do most things but spacing thing equally and to the scale of the enclosure proves difficult.
Pcbs no longer available
This one should be printed at 300DPI.
[attachment deleted by admin]
jimmybjj
teknoman2
Does anyone have Brian's drilling template for zombii?
I think its been deleted.
Thanx a lot
Haberdasher
I think this is it but I'm not 100% sure.  Measure carefully as always.
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
teknoman2
I believe that this template is for 9mm Alpha pots,
I will check it though.
Thanx mate.
pryde
Here is a version 4 Zombii build doc with a drill template. Not sure if this is what you want?
