Kingslayer , buffered or True bypass?
Started by MIM#1, September 24, 2012, 02:18:35 PM
MIM#1
Hi folks, I'm installing my kingslayer in a 3in1 enclosure between a fatpants and Dyna red circuit.The other two will be true bypass. Can I still wire the Kingslayer in buffered mode when connected to 2 other true bypass circuits/switches in the same box?
Thanks in advance for any insight on this!
Absolutely. No difference than if they were three separate pedals connected together or three in one box. Your input and outputs are just connected to the other 3PDTs or jacks depending on what order you are putting the FX in there.
MIM#1
^ Thanks Brian! Great PCB's by the way!  ;D
MIM#1
One last Kingslayer question:
If I want the soft clipping diodes in the feedback loop always active,would I simply jumper the 2 pads for the SPST switch  ???
Thanks!
Vallhagen
Quote from: MIM#1 on October 07, 2012, 10:15:48 AM
Thanks!
Yessir, simple as that:)
Cheers
