Doombutter Fuzz Lift
Started by Guybrush, October 05, 2012, 09:41:15 PM
Guybrush
Some time back Haberdasher etched me the attached version of the Doombutter:
I want to add a switch for the fuzz lift mod but can't work out how to do it. There are two pads towards the bottom left of the layout marked Lift 1 and 2 so I'm assuming I have to solder a switch there. I'm a bit clueless on what kind of switch I'll need (SPDT On-Off at a guess) and how to wire it up.
Please could someone help me out?
Thanks guys.
Hangingmonkey
Haberdasher etched me one too.  Its a great project and a great pedal to mess around with.
Just link those 2 pads to an spst or if you want to use a spdt just use the center pin and one of the other 2 pins
Guybrush
Thank you very much.
Greatly appreciated!
bigrigg
Quote from: Guybrush on October 05, 2012, 09:41:15 PM
Thanks guys.
I don't know his pcb, but schematic wise it's just a simple cut between the connection of Pin 1 and Pin 8.  A simple spst or dpst switch will work.  On or off.  That's it.  Good luck.
