would these work well as signal isolation transformers?
Started by jimijam, August 08, 2012, 05:13:32 PM
jimijam
found these while researching a project and was wondering if they would work well to eliminate ground loop hum when used as isolaters.
http://www.ebay.com/itm/ESAN-S4T-21G-Encapsulated-Toroidal-Transformer-Qty-10-/120919766410?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item1c2761358a#ht_1342wt_1151
I am just starting to read up on transformers and would like someone with a little more wisdom on this stuff to chime in. I could definately use some of these from time to time (if they do what I think they will)
oldhousescott
You'll need something more like this from Weber:
https://taweber.powweb.com/store/balun.jpg
Edcor has something similar, probably better quality:
http://www.edcorusa.com/c/13/wsmseries
Then you get into the high zoot stuff, Jensen, Cinemag, Sowter.
jimijam
