Scheduled maintenance on 08.23 at 10am Central Time
Started by madbean, August 22, 2013, 04:27:53 PM
On Friday, 08.23, I will be doing some maintenance to the forum and website. This will be mostly backend stuff, and will require several hours to complete. You should expect the MBP website to be unavailable for 12-24 hours while this is taking place.
Once complete, the forum will be fully upgraded (which should prevent any further downtime) and the site will be on a new server.
Yaaaay madbean3.0 or for those if us in the south, 3 point naught.
muddyfox
Will Tapatalk access bi fixed as well? It has been acting up for the last few days...
The taptalk plugin is active now...are people having trouble? What sort?
muddyfox
I can't log in with tapatalk pro v2.2.
It gives me the "login failed, you entered wrong pass or tapatalk is disabled" spiel even though I clearly know my password.  ::)
billstein
Quote from: madbean on August 22, 2013, 08:59:49 PM
I haven't been able to log in either. Keep getting a "Failed to connect to forum. Contact the administrator" message.
GhostofJohnToad
Also the newer tapatalk version was working fine before the site went down, after it went down and came back up  the login error began.
Okay, thanks for letting me know. Part of the upgrade will be taking the forum and database to the latest version, which is SMF 2.05 I think. I will be reloading all the plugins as well on the new server. Hopefully that will fix the issue. And my madbeanpedals email will finally be working again.
If there are any other forum features/plugins you like, let me know and I will see if I can incorporate them.
