Masochism is the new Feng Shui!
Started by GrindCustoms, February 21, 2013, 04:03:14 PM
GrindCustoms
Yosky all, makes a while i have'nt posted here.
So this is another Zendrive type OD in a mini, since there's quite couple fans of 1590A builts on here i though i'd share this one that i've built couple weeks ago.
njkke
GrindCustoms
Thanks, i have received last week some 9mm pot daugther boards for my mini-builts....going to make them easier and neater......will report once in use :)
Stomptown
Great looking build! Can you explain how you did the enclosure and what is going on the the solder terminals on the pots?
GrindCustoms
Quote from: Stomptown on February 23, 2013, 10:45:46 PM
Thanks, the enclosure finish is simple black paint directly on aluminum and baked. I then use 0000 Steel Wool to get the distressed look. Labeling is done with «Letter Punch». Pretty simple and straitght forward.
For the pots it's just shrink wrap around the lugs to avoid any chances of contact since 4x 16mm pots is a tight fit in there.
