Serendipity Hiss
Started by insomniac2295, May 18, 2012, 01:52:19 AM
insomniac2295
Just built the Serendipity and everything works and sounds great, except for a large amount of hiss when the effect is engaged. This his is made exponentially worse when any of the pots are turned up past noon. I've tried several different ICs and still the same problem. I'm using a JRC4558D
insomniac2295
Solved! Stupid solution  :P
